no water comes out from the brewer head
For my machine, it even stopped making sound, of cause no water comes out from the brewer head. What could this mean? a broken pump?
Cheers,
Jin
この質問は役に立ちましたか?
Cheers,
Jin
この質問は役に立ちましたか?
If the machine has power (heats, lights come on) but the pump doesn't make a sound when either the coffee button is pressed or the steam knob is turned, then yes it's possible the pump is completely dead. This is very rare though so I would make sure to check all the wiring and ensure the pump is getting power.
このアンサーは役に立ちましたか?
Thermal fuse which on the white wire may be blowed, use ohm meter to check,
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 10
今までの合計 707
1件のコメント
Mine has this issue and the pump labors to work. No water comes out.
Javagirrl さんによる
