メインコンテンツにスキップ
モデル番号 A1051 / 4 もしくは6 GB ハードドライブ
89回答 すべてを表示
Can battery be charged outside of case?
Looking to be able to charge my spare Mini batteries using a portable Li On charger. Is this possible? I am repairing ipod minis as a hobby and I have several batteries that I want to charge before I install them! Is this possible?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Single cells can be charged using a regulated power supply set to a voltage of 4.2 V, and a current limit appropriate to the size of the cell you'd want to charge, say about 0.5C - which means, if your cell has a capacity of 1000mAh you'd set the current limit at 500mA. A seasoned electronics engineer could slap together such a circuit from parts in the junk drawer. Carefully check that the voltage doesn't drift upwards as the circuit warms up under load, and adjust accordingly if it does.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Steve Barthel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 219
