メインコンテンツにスキップ
MacBook、MacBook Pro、MacBook Air用のAC電源アダプタです。引っ張られても安全に外れる整列式の磁気コネクタを採用しています。第一世代 (2006-2012)のMagSafe充電器は、コネクタがやや太いL字型になっています。45W、60W、85Wの3種類があります。
65回答 すべてを表示
Is it normal to have white paste inside charger or something leaked?
I decided to replace a cable in my MacBook charger (old MagSafe). I cracked it open and there is a large blob of some sort of white rubberish paste filling a good portion of the space inside:
I am not sure whether it is a special filling paste or something (capacitor?) leaked. I was not able to find any obvious sorts of leakage.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
ベストアンサー
The white rubbery stuff is indeed a filler, I think it may help conduct heat towards the shell so as to avoid the formation of hot spots in the circuitry. It also helps to keep the components in place, which is a good thing because power bricks are relatively prone to rough handling.
Of course, it also makes the power brick more difficult to repair, but then, power bricks as a rule should be replaced, not repaired. Repair of power bricks by non-experts in particular are not unlikely to present a significant safety hazard.
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
I just replaced the cable by unsoldering the old one and soldering new one. I would barely call it a repair. The place where wires were soldered was not covered by the filler, so it was not hard at all.
さんによる
There's always the exception that confirms the rule ;)
However, one should keep in mind that a carelessly executed repair might compromise the galvanic separation between input (mains!) and output (the equipment being powered, and by extension, your body).
さんによる
Thanks I will keep it in mind.
さんによる
コメントを追加
回答を追加する
Andrey さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 18
過去 30 日: 47
今までの合計 5,126
