Jerking upon opening garage initially
Lately, when I go to open my garage door, it jerks and then stops. I have to then close it and start again to open it. What could cause it to do this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The rollers on the side are binding in the tracks. Track bent? Roller bent?
このアンサーは役に立ちましたか?
Thanks, will have to check if they are bent.
Check the rollers on each side, make sure the are not crooked, binding, or other wise. Often the tracks that they run in can get a little tweeted, and this can cause issues, especially where the two pieces meet. Could be binding there.
このアンサーは役に立ちましたか?
If your door still has a manual lock on it, sometimes the bar can catch on the track as it passes through the curve.
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 6
過去 30 日: 8
今までの合計 4,201
1件のコメント
@mactechplus thought you might have some advice on this one.
mayer さんによる
