メインコンテンツにスキップ
モデル番号A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5もしくは 3.4 GHz Core i7 Processor, ID iMac12,2
708回答 すべてを表示
How can you test the power supply
My iMac doesn't power up. I watched a video on how to change the power supply but how can I check to see if the power supply is or is not working properly? Could my iMac have another issue as to why it is not powering up? It seems like there isn't any power getting to the computer at all. I checked the power cord and there is power going through the actual power cord from the outlet. I also checked to make sure there was power coming through the line that connects to the power supply (the 2 prong connection). Could it be the power button itself? And can the power button be replaced?
Update (04/25/2016)
I don't see any LED lights inside my iMac. I've looked for them.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
What are the diagnostic LEDs telling you?
さんによる
I have same problem too on my 27" iMac. Mine is showing only one led light on the board. please help!
さんによる
コメントを追加
1 件の回答
ベストアンサー
On the 2011 model the diagnostic LEDs are located to the right of the RAM slots. On other models they are in different locations and we have to know your exact model.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
i think shannon was referring to the output voltage coming out of the power supply. how do we test these and what should be the voltages?
さんによる
コメントを追加
回答を追加する
SHANNON さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 1,398
