Why does the audio sound weird?
The sounds that are playing from my device sound distorted and crackly, what can I do to fix this issue?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It sounds like there's a loose connection between the speaker and the circuit board. This may mean that you'll need to re-solder the connections between the two. Use this replacement guide to learn how to access these connections. Hope this helps!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 61
