damaged sim card slot
sim slot pins were accidently broken while trying to insert sim card.is repairing or replacement of slot is possible?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi abhijith jayakumar,
Yes! If you can purchase a new SIM card reader, the piece is replaceable! A guide has been written to explain this process and will likely be published within two weeks. When it becomes available, you should be able to access it with this link:
Motorola Moto G 3rd Generation SIM/SD Card PCB Replacement
Good luck!
James
このアンサーは役に立ちましたか?
Yes, it is possible for repairs if the damage is not that much but can be too if it is severely damaged
このアンサーは役に立ちましたか?
I broke my tray what do I do
このアンサーは役に立ちましたか?
Miss COnger there really is no Sim card tray on this. You may have broken the card reader? We would need to see what this looks like. Post a couple of pictures with your ANSWER (you need to edit it) so we can see what is going on. Adding images to an existing answer
We can then convert this to a separate question and hopefully help you fixing this.
過去 24時間: 2
過去 7 日: 3
過去 30 日: 19
今までの合計 34,562
2 件のコメント
The Nano Micro combo sim cards are the foolish thing the service providers do If we use the sim as micro it gets split up and damages the mobile sim slot
snpillai4 さんによる
i have to need only one Sim Slot (Sim Jacket) for My Cell Phone Motorola XT1032
Albert Aienstein さんによる
