メインコンテンツにスキップ
Asusによって製造されれたラップトップコンピューターの解体と修理情報です。
2531回答 すべてを表示
How can I open an Asus Zen aio pro 240ic
Hi there, is it posible to tell me how to open an Asus aio zen pro (240ic) in order to upgrade the hdd?
I think a lot of people will be interested in this because is a beast of a computer with a big handicap: hdd.
Looking forward to hearing from you
Best regards,
Valentin
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 8
コメントを追加
10件の回答
ベストアンサー
Here's some pictures of the open PC. I follow the instructions of Valentin and eveything's fine.
Be carefull when you pull the screen... the cables are fragiles...
このアンサーは役に立ちましたか?
スコア 10
8 件のコメント:
Thank you, that's very helpful!
さんによる
Cheers! That's great. :)
さんによる
Do you know if you can access the RAM when it's open or is it buried under the motherboard?
さんによる
For the hard drive of course it's ok... RAM i don't know.
さんによる
Does someone has a solution for the noisy fan?
さんによる
3件以上のコメントを表示
コメントを追加
Finally i managed to open the ZEN 240IC.
I will be brief now because i am very tired and i managed to snap 1 connector from the ribbon cable.
So to open the PC you need to remove FIRST the small black plastic cover from the bottom of the screen. This will reveal some screws.
In order to do that i used the hair dryer to heat it a bit because the adhesive is quite strong on it.
After i removed that i used 2 suction cups ordered from Ebay to gently pull the top corners of the screen. I used 2 cups, 1 on each corner.
This requires patience as i struggle a bit to be able to pull the top part of the screen.
After the screen is detached you have some cables you need to remove in order to completly remove the screen.
One of the cables was the ribbon one from the motherboard to the screen...this was my luck.
Inside the HDD is clearly visible on the right side and without removing the motherboard there is no trace of another sata slot or PCIE M2 ssd or anything else.
I have just swapped the HDD with a SSD and that was it.
Hope this info is helpful to someone and please take good care when you remove the cables because now for me is a mission trying to get a new one from ASUS or to repair this broke one.
Good luck
このアンサーは役に立ちましたか?
スコア 6
5 件のコメント:
bonjour,
pouvez vous ajouter quelques photos ?
Merci
FV
さんによる
V. interesting. I've contacted my reseller and then also ASUS, but both deny any way to open it. While I knew it is possible, they did not teleport the parts inside.
Oh yes please, pretty please :) Some photos or a video of the process would be gold! Even if just an assembly back together. Thank you
さんによる
Thanks so much! I might actually buy one now. It has such potential to be a great unit. :)
さんによる
One quick question; Is the RAM accessible? I want to upgrade the hard drive and RAM when I buy one. Thanks!
さんによる
I have this pc and I want to add RAM to it myself, also where do you get the tool to remove the plastic trim on the bottom like Alredo Fresser did in the YouTube video?? After opening the computer how do you reinstall the black trim under the screen? if you have to get a new trim piece, from where? and if you have to re apply adhesive, what kind?
さんによる
コメントを追加
I found this video recently on youtube. I hope its will be helpful for all of us.
http://youtube.com/watch?v=U06F4trdXC4
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
I've review the video, it is helpful, but a little bit short. We can't see the more detail inside. Anyway, thanks for your info.
さんによる
コメントを追加
some fotos, and RAM's slots
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Thanks so much!! One question only: can we see a video tutorial please? Thanks! :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Tanks for your feedback. I also would like to change my hdd. Is it a problem to put back in place the small black plastic cover from the bottom of the screen?
Many thanks
Thierry
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Not at all... very easy
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hi there is the Memory RAM is accessible? where is it located? Thank you in advance.
さんによる
RAM is accesible and changeable. You can find it from another of seen side of motherboard. 2 slots under cover.
さんによる
コメントを追加
Please help. where is the M2 slot?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi, is the HDD size 3.5" or 2.5"? Thanks
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The HDD is 2.5"
さんによる
コメントを追加
does anyone know if you can find the replacement for the external glass part? the screen that has the touch?
I cracked it when opening and everything works, but it has the cracked lines and I would like to replace this screen.
please point me to where I can buy it.
thank you!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I believe it's this one - http://www.asusparts.eu/en/Asus-18010-23...
Just check that the part number you have on your screen (from back after you open it) matches.
It's such a nice computer but it was very dissappointing that it was obviously made not to be opened or upgraded.
さんによる
wow, it's expensive!
thank you, I will have to open it again just to be sure.
thanks!
さんによる
コメントを追加
回答を追加する
Valentin iacobescu さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 22
今までの合計 14,872
