メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Released in 2008, has 30 pin connector (can be used with iPhone 4S and below) which will not work with newer models. The main differences between this model and the first edition is the remotes layout and color. Product features include: rechargeable lithium-ion battery, rotating docking system, remote, portable, built in carrying handle, and Bose quality speaker.
Why the green light is permanent?
Hi, my Bose SoundDock Portable v2 has the green light permanent, and a i can´t use it. I can´t turn up the volume or turn down, and don´t reproduces the music.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
It worked like a charm !! Thanks !
さんによる
コメントを追加
5件の回答
ベストアンサー
Is this with both the buttons on the device and the remote?
このアンサーは役に立ちましたか?
スコア 3
15 件のコメント:
No, when i press the buttons on the device or the remote, my bose doesn't make anything, the green light stay permanent
さんによる
I'm certain you've tried unplugging it and waiting a while before you use it again. Also I'm wondering if it works while its plugged in. It could be a faulty battery, for which you could Bose SoundDock Portable v2 Battery Replacement replace the battery
さんによる
i have the same problem with my bose soundock series ii, the bose sevice center told me that it need to replace the sound processor module but very expensive so i try to repair it myself, i found out that the crystal oscillator 16.974mhz is not working properly, tried to replace it but no luck, so i solder a 22pf capacitor to one pin of crystal to ground, now its working.
さんによる
Hey Marvin, you didn;t happen to take a photo of your completed fix? Thanks,
さんによる
Hello Marvin can you please attached the photos so it will be easy to fix the issue mine have same problem please help
さんによる
10件以上のコメントを表示
コメントを追加
hello do you have to regulate your problem??
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This is the fix you need
画像
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
22pf ceramic capacitor
さんによる
Thank you, worked like a charm
さんによる
22pf capacitor 50v?
さんによる
It worked like a charm ! THANKS !! How did you find this solution ?
さんによる
コメントを追加
Hello all. My SoundDock Series II does the same thing. For a while the green LED would stay lit after a power outage, but would be fixed by replugging the power cable on back of unit -- now that method doesn't work. I suspect there is an issue with the power supply, or with the power stable circuit. I will pursue this problem and post any conclusions.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Would like to know what the fix is for this issue when it's available, would like my SoundDock working again.
Thanks.
さんによる
コメントを追加
this happens to my device only in cold weather. replugging it after a while fixes the issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Romer Alvarado さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 21
過去 30 日: 119
今までの合計 8,605
