broken sprocket teeth repair
one of my motors has had two sprocket teeth break on the smaller sprocket on the underside of the motor. is there any way to repair that and if not is there a guide on how to replace that part?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Here is a link to the Syma website X5C replacement parts page. You may be able to find exactly what you need here.
http://www.symatoystore.com/Syma-Spare-P...
Hopefully this is of some help.
このアンサーは役に立ちましたか?
There is an epoxy that's been around a long time and well respected due to it's abilities to permanently repair broken metals, after it hardens it's even machinable.
"J-B Weld" can most likely repair the gear for good. Comes down to how well can you shape/machine the sprocket to match the others.
It's available almost anywhere, auto shops for sure.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 10
今までの合計 1,677
