メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
when I turn on the camera it say memory card locked
why does it say memory card locked ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 9
4 件のコメント
Thanks so much for fixing a problem that foxed me. All now working perfectly again. Bless you!
さんによる
Hello, I am having a similar issue with my Canon PowerShot SX620 HS but flicking the memory card switch doesn’t have an effect. I’ve also tried three different memory cards and the camera is showing the same error message so I feel it’s probably a problem with the camera itself. Has anybody got any possible solutions? Thank you!
さんによる
Hi,
I am having a similar issue as well with my Canon PowerShot ELPH 360 HS. Like the previous comment, I have tried clicking the tap on the memory card to locked, unlocked, etc. Nothing happened. I tried multiple memory cards as well, and the message still said "memory card error" and under that: "memory card locked"
My sister has the same camera and this has never happened to hers.
Any help would be appreciated. Thanks!
さんによる
Yup: I just bought a new card and when I inserted it the camera said « card error »
After much fuffing about including going back to the shop where I bought it, I found out that what I thought was the card was actually just the card holder and the card was actually I tiny square of plastic which has to be inserted into the card holder. I don’t remember that ever being the case before????
さんによる
コメントを追加
4件の回答
ベストアンサー
SD cards have a tiny little tab on the left side edge (as seen from the front of the card). When this tab is in the LOCK position, a sensor switch in the camera tells the camera that the card should not be written to, i.e. the card is locked.
  • Remove the SD card from the camera. Check the position of the locking tab and make sure it is not in the LOCK position. Reinsert the card, and try again.
  • If you are positively sure that the locking tab is not in the LOCK position, and the camera continues to tell you the card is locked, the camera's sensor switch might be stuck.
  • Sometimes, the locking tab pops out of its notch and goes missing. If you see the notch where the locking tab should be, but the locking tab itself is absent, you can tape over the notch with a tiny piece of thin adhesive tape. Be careful, if this is not done cleanly or the tape is too thick, the SD card might get stuck in the slot and you'll have difficulty getting it to eject.
  • Inserting and releasing the card a few times, thereby jogging the sensor switch, may clear the problem.
  • As a last resort, you can give the SD card slot a blast of compressed air from a can. Be careful because the "air" from the can might cool down the card slot to the point of causing condensation, so wait a while before turning the camera on again.
  • If the problem refuses to clear, have the camera looked at by someone knowledgeable.
このアンサーは役に立ちましたか?
スコア 17
16 件のコメント:
This was driving me nuts...after reding your solution I took the card and battery out of my canon ixus and blew hard into the space...Hey Presto! everything works. Thanks dude
さんによる
Wow just worked thanks mahn✌
さんによる
it does not work man
さんによる
Tried what you suggested,worked perfectly,thank you so much.
さんによる
Thank you, it was driving me nuts as well. Had no idea about the SD being tabbed.
さんによる
11件以上のコメントを表示
コメントを追加
There is a switch on the top left of the memory card. Switch it up.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
For me, I think it was my memory card that had a problem. I tried flipping the switch several time and it still didn’t work, then when I tried a different memory card it worked
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My experience with the same problem: Card A for Camera A was unlocked (tab in the upper position) and it would still not work after my blowing some dry air into the slot. Tried Card B in Camera A and it worked, so I thought Card A was the problem. Tried Card A in Camera B and it worked. Weird.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
drogerpoche さん、ありがとうございました!
統計データ:
過去 24時間: 14
過去 7 日: 91
過去 30 日: 472
今までの合計 119,078
