Why does my fuze turn off when I turn it on
why does my fuze keep cutting off? i turn it on and it says something about stand by mode and cuts off. if i get it to play it stays on for a moment and blacks out
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Have you tried to reset your player?
Here is a link that shows how to do it. Scroll down to find the procedure applicable to your model.
http://kb.sandisk.com/app/answers/detail...
If that fails to solve your problem, you could try and see if there is a firmware update that you can load into your player to see if that solves your problem.
Be aware that doing a firmware update can sometimes erase all of your data and it will restore the device to a factory default condition. If you can, copy your data before you try this.
Here is a link that shows you what to do.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 121
