What do I do if the propellers don't spin?
The remote and the drone turn on fine, but the drone propellers don't spin when throttled from the remote.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If the propellers don't spin the first thing you want to check is that the drone is on and working. If it is running and 1+ propellers just aren't spinning, then the next step is to check to see if any dirt or debris is stuck in the propellers. If the propellers are clean, check to see if they're broken and check to see if they spin when you spin them.
このアンサーは役に立ちましたか?
One of my propellers still don't work
Same here. It locked up and I have taken it apart and cleaned it. Still locked up.
Since you have another question about the mode button and syncing, I think you just need to sync it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 1,365
