My fan is not running
Is the fan suppose to operate from power-up and keep running.Mine does not and my system freezes after 6-10 minutes operation.
Most likely is that you need to replace the fan. Here's how to do it: iBook G4 14" 933 MHz-1.33 GHz Fan (1.33 GHz) Replacement
Here's the part: [リンクされた製品が存在しない、もしくは無効: IF184-006]
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,268
2 件のコメント
The fan can run. Whilst fiddling with GPU the fan ran continuously as the GPU chip got hot.
Aston Ffrench さんによる
The question is now, is not can the fan run,but should it run at start up and continue during use ad infinitum.
Aston Ffrench さんによる
