メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
727回答 すべてを表示
Why Am I Still Having Wi-Fi Issues?
Okay, so, I've tried everything. In no specific order, I've factory reset the console, I've done a hard shutdown, I've changed WiFi names and passwords, used no password, etc. It's not that the Xbox won't connect, it doesn't even find the network! And if I try 'Test Network Connection' it gives me an error and says my hardware is messed up and I have to send it in. So I went out and bought a WiFi Card for the Xbox and replaced it myself (super easy, the case pops off and there's 2 screws holding the chip). I powered it up and BAM it works. I play a bit, watch some YouTube and then I went to bed. I get up this morning ready to play and it's doing the EXACT. SAME. THING. What could it be? The only thing I can possibly think of is my Internet source which is a mobile hotspot. But it worked last night, so I have no idea.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
Are you using the "new Xbox experience"? I had a similar problem... It was a driver problem that was fixed...
さんによる
コメントを追加
1 件の回答
When the XBOX can't your hotspot, have you checked to see if any other devices can see it?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jared Horne さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 110
