メインコンテンツにスキップ
A new iteration of the set-top box, a side-set box. Chromecast connects to your Wi-Fi network to stream content from your compatible device to your television.
10回答 すべてを表示
device seems to have renamed itself after windows 10 update
device is saying it can't be found and or when it seems to work it says it is casting to a bastardized network name, after windows 10 latest update. worked fine before .. did mention no one likes windows 10..
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi there,
With regard to your query, I suggest that you install the most recent driver for any external devices. This issue may happen if haven't installed appropriate driver for your device.
If these steps don't work, try reinstalling the driver:
  1. Open Device Manager.
  2. Right-click the name of the device, and select Uninstall.
  3. Restart your PC and Windows will attempt to reinstall the driver.
To keep the security of your data, I suggest you make backup with MiniTool ShadowMaker or Windows built-in backup utility.
Hope this info help you. Thanks!
Update us with the result.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lithamoonsong さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 113
