メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
Extreme lag MacBook Pro
I have a macbook pro 13" unibody mid 2012 model ibe had it for roughly 4 years now
Today i started up my mac and it took 30min for it just to start up and load the log in screen and i fell asleep multiple times during start up. Once it started up i typed in my password and it took about 30min to log in. Then once i was finnaly logged in simply opening a folder caused it to experience more extreme lag again taking about 30min to open the folder.
I have taken the laptop to a guy twice for other problems and he said that he "rebuilt the harddrive" anyone now what this means???
Also before this when playing videos the video would freeze continue to play audio then skip 10-20 minutes of video then continue to play as normal
Is there a way yo fix this lag preferably without losing my data because not all of it is backed up
Or should i just replace the harddrive
PS i would prefer not to take it to apple because the first time i took my laptop to them they fixed nothing and charged us about $100-$200
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
I am assuming when he said he rebuilt the HDD that he had to run Disk Repair on it which means that the HDD Sectors are going bad. It would probably be best for you to do a backup/image to a portable HDD and then replace the HDD and then do a restore. Depending on the Size of your current drive you might be able to get a larger and faster one at a reasonable price.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Daniel Iaria さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 485
