メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Thin, light and powerful with incredible sound and Wi-Fi capabilities is what everyone needs to have on the go.
How can I remove and replace the screen from the LCD cover?
The hinges for my display stop rotating so much. Eventually the plastic molds of the LCD cover (ferrules) broke off and the display is no longer attached to the hinges.
More info here:
http://forum.notebookreview.com/threads/...
So I want to by a LCD cover replacement and swap my current display into it. If I wanted to remove the display from my broken LCD cover how would I do that?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
Just figured it out while replacing my LCD cover.
When you have the screen separated from the body (and the hinge cover in the middle taken off as well), you need to hold the LCD cover (the back) steady, and slide the front with the screen downwards.
You should see a little gap form and stay at the top between the cover and the screen now.
After that, just apply a little upward pressure from the bottom in one of the sturdier spots between the screw holes, and the LCD should come up.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jude Wynn さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 37
今までの合計 1,995
