メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1136/30、60、80GBハードドライブ/ブラックまたは白のプラスチックフロント
iPod Video No Sound at All
Hello everyone. I have an ipod video 5.5 30 GB with no sound neither on the line out (dock connector) nor in the headphone jack. Now, I know the problem lies in an IC in the logic board and can be fixed by performing a reflow.
My question is: which IC I need to heat up?
Thanks a lot for any answers.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
@newtonian first you should tell us if it syncs properly and if you can access your files with music while the iPod is in diskmode. After that you want to place your iPod into diagnostic mode and see if you get any errors (you may get a FW error). If none of that shows any issues, you may have problems with the audio IC. In the case of your iPod I am leaning more toward this problem. This particular model has a problem with an IC on the logic board. You can try and see if you get sounds by applying some pressure to the right lower side of the ipod, almost between the click wheel and the bottom corner. If you should get sound by doing so, then you only have very few options. One is a new logic board, the other one is to reflow your old logic board. Or you can try what warnergt did on http://forums.macnn.com/103/ipod-iphone-... By now I can verify that this works since I performed a reflow on three of the boards and it solved the problem. The logic board is of course available at ifixit as well."
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
Thanks oldturkey03! The device can sync properly and I can indeed access my music files in disk mode. No trouble in diagnostic mode, except for 5 reallocs in the hard drive. I will try to do a reflow and report back.
さんによる
could i reflow solder using a heat gun/ blow dryer on mobo, or use the xbox 360 wet towel trick(probably no for that one)
さんによる
@technokat348 not a probable but an absolute "NO" to this one "xbox 360 wet towel trick" This one "blow dryer on mobo" will not work Hair dryer for logic board reflow? Leaves you with "using a heat gun" Hair dryer for logic board reflow?
さんによる
コメントを追加
回答を追加する
Miguel さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 55
今までの合計 7,869
