Smoke after mower runs for 5-7 minutes.
I recently changed the oil in my mower. Since then it runs normally for about 5-7 minutes then white smoke starts pouring out the exhaust. Any ideas?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@toro you did check the oil level to make sure you did not overfill it. You did not tilt it over while you were doing the oil change, this could lead to oil in the combustion chamber. It will help if you let us know what model your Toro is and what engine model you have.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 101
1件のコメント
is the smoke white or blue ...ish. How big is your lawnmower and does it have a liquid cooling system?
Jimfixer さんによる
