メインコンテンツにスキップ
The Samsung Chromebook XE303C12-A01US laptop features an 11.6" screen and a 16 GB SSD hard drive. This small notebook computer allows for easy access to the Internet and can run various web apps.
37回答 すべてを表示
What do I do with a broken bezel on my chrome book
So the bezel around my chromebook cracked in one corner and it just got worse from that. The hinge on the left for the screen is detached and it's only worse if I try to open or close it. What should I do? The warranty doesn't cover this either so it's kind of difficult to get it repaired.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Can you post a photo of the damage? I may have a way to repair it.
さんによる
What's your email
さんによる
Ichbinderarzt@gmail.com
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Sounds like the hinge mounting points on the LCD cover have broken. You will need to replace the LCD cover and the screen bezel. It isn't terribly difficult to do if you are comfortable with laptop repairs. You will need to remove the screen assembly, disassemble the screen assembly and transfer the panel, webcam, WiFi antenna, etc. to the new cover, snap on the new bezel and reinstall the screen assembly. Otherwise any PC repair shop can do it (not GeekSquad or Office Depot).
Replacement parts are available on eBay, but in order to get new and not used parts the LCD cover would have to be ordered from Asia.
http://www.ebay.com/itm/Genuine-Original...
http://www.ebay.com/itm/New-Genuine-Sams...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Duncan さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 19
今までの合計 1,768
