メインコンテンツにスキップ
Sony Xperia Z5 は5.2インチ、1080 x 1920ピクセルディスプレイ、 3GB RAM/23 MP のリアカメラ、Qualcomm Snapdragon 810プロセッサーを搭載しています。
Xperia Z5 LCD connector or screen?
My screen is not cracked, but half of it is dead or with discolored vertical lines. Will replacing the LCD screen fix this, or could the screen be fine but be an issue with something else? Are connectors included with LCDs when purchased?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
While I can make no promises, it should fix the issue. Was the phone dropped, or did this randomly occur?
The LCD and glass digitizer are fused together, so when you replace one you will be replacing both. The flex cables that attach the LCD and digitizer to the motherboard are included with every new screen. However, you will need to buy new adhesive for the screen.
This is a good example of the tape (however, this is a more expensive five pack). The LCD can be purchased here, as iFixit does not sell parts for this phone. If you follow the instructions on iFixit and take your time, your phone should turn out fine.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks. The phone was dropped and hit the floor parallel to it. I'll try to fix it myself.
さんによる
コメントを追加
回答を追加する
Johnny さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 1,563
