メインコンテンツにスキップ
The Microsoft Surface RT (model 1516) is the first tablet released by Microsoft. It runs Windows RT, which is designed specifically for tablet functionality. Repairs for this device require screwdrivers and prying tools.
57回答 すべてを表示
Are These Charging Contacts Burned on my Surface RT?
So this has happened, not quite sure what to do, I've ordered a new charger, but also want to know if I should be replacing the charger port? Is there someway to clean it or is it toast? I have found the instructions and parts here, I could do it, just wondering if I MUST..... The Surface RT is working but I don't want to use it until I get this sorted out, I use it daily, but have other computers, will be going through withdrawal .... All help appreciated, thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
New charger arrive, the second I plugged it in I smelled burning, so I know it's not the charger, next step is replace the port and then if that doesn't work, get a new tablet ...
さんによる
コメントを追加
2件の回答
選択されたソリューション
Replace the charger and clean the contacts on the tablet with some alcohol and use #0000 steel wool (very fine) to remove anything that will not come off w/ the alcohol. Make sure the tablet is off if and when you use the steel wool. You could also use a plastic bristled brush. Nothing too abrasive.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I have already ordered a charger and didn't want to use it until I sorted out what to do with the port. Thank you so much for the advice! :)
さんによる
No problem. Thanks for the upvote.
さんによる
Did the new charger alone work for this? I also experienced this issue/problem.
さんによる
コメントを追加
The new charger hasn't arrived yet! Bah!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Where did you order your charger from? Just wondering so I'll know not to order from there. lol
さんによる
コメントを追加
回答を追加する
shanonmc さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 1,264
