2001 SV 650 S 36.000Km - water in the oil/ creamy substance
Hi guys,
I need your help! What things could be at fault when there is a creamy substance (probably water-oil suspension) under the lid where you fill in the oil, as well as small droplets of clear water found under it? I am suspecting a seal near the waterpump and hoping very much it won't be the head gasket!
Are there any known conditions to cause these symptoms?
Cheers and thanks in advance,
Simon
この質問は役に立ちましたか?
