メインコンテンツにスキップ
GMが所有するHummerによって設計された生産外のSUVやトラックの修理ガイドとサポート。
28回答 すべてを表示
oil pressure is on 0
2008 Hummer 2 changed my oil and when i started the car the oil pressure said 0 i am looking for where the pressure sensor gauge is located. i bought on but cant find it. and not sure its the right direction
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
did you put the oil plug in when you changed the oil or the oil filter you didnt just dump what oil you put in check the level of the oil in the engine
さんによる
コメントを追加
1 件の回答
最も参考になった回答
When you change engine oil and filter it is normal for an engine to take a few seconds to read pressure. Assuming all was fine before you changed oil, @jimfixer has your solution. Check your oil level. If oil level and filter are fine, you need to use an obd II diagnostic machine that can read "live data" from the vehicle. It will show your oil pressure. If the sender is bad, the location depends on what engine is in your H2. Usually on the back edge of motor, just behind the intake manifold on GM engines.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
matteo siano さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 192
