Does iFixit sell a vibrator switch for the iPhone 3GS?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Can anyone tell me how to remove the vibrator switch from the metal housing it's in? The original looks like a rivet because the back looks like a mushroom. The new switch which is part of the flex has the two legs but they are straight. Do I need to solder them or do anything else once I stick the new switch flex to the housing?
このアンサーは役に立ちましたか?
mikev0521, it would be better for you to ask your own question. this one here has had no answer for 8month. your question shows up as an answer. I am certain that there are plenty of knowledgeable people out there that are going to help you, if they see you are asking. Good Luck
The vibration switch is actually a part of the headphone jack assembly. Here is the part and here is the guide for the replacement
Hope this helps!
このアンサーは役に立ちましたか?
what, did you read Nicks answer to get this response?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,823
