Focus Indicator does not show up AF will not lock with viewfinder
Hello,
I accidentally dropped my D610 when my camera bag's sling snapped... When I tried to check the camera, AF cannot lock on a subject and the green circle focus indicator between the green arrows would not show up.. I tried resetting the camera to factory settings and still encountered the same problem, also tried playing with the different AF modes and still problem could not be solved.
By the way, when I press the shutter lens will be moving back and forth but will not lock, I tried also to use several lens to test it and still it gives me the same problem.
When using live view everything is normal. AF can lock the subject.
I am very confused right now and i am running out of options on how to fix it myself.
Thanks in advance for any advise/help on the matter..
JO
この質問は役に立ちましたか?
