メインコンテンツにスキップ
2013年6月に発売されたGalaxy Megaは、720Pディスプレイ、デュアルコアプロセッサ、8 MPカメラを搭載した6.3インチスマートフォンです。
54回答 すべてを表示
Can't entering recovery mode
hi please can you help me my phone when i boot into recovery mode it gives me e:failed to mount system and don't enter into recovery.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
ベストアンサー
That means the chances of getting the phone back into a working state via recovery is 0%. You will have to attempt restoring the system software via download mode which is done by this:
(Before you follow the steps below, make sure your phone is turned off then booted to download mode by holding Volume Down, Home Button and power button. For a few seconds until the download mode confirmation dialog is shown. Make sure to accept booting that mode via volume keys when prompted.
You may need to restore the software on your phone via Samsung Kies. You do it via Tools > Firmware upgrade and initialization. This will prompt you to enter the model number and the serial number of the phone which is usually at the back of the phone or in the battery compartment.
If the Samsung Kies method does not allow you to download the firmware for your phone then you'll have to go to http://www.sammobile.com/firmwares/ where you type your model number of your phone to find the firmware for your phone. Make sure you choose latest version to the network it was mainly with.
Samfirmware instructions (After the file has finished downloading):
  1. Extract (unzip) the firmware file
  2. Download Odin v3.10.7
  3. Extract Odin ZIP file
  4. Open Odin v3.10.7
  5. Reboot Phone in Download Mode (press and hold Home + Power + Volume Down buttons)
  6. Connect phone and wait until you get a blue sign in Odin
  7. Add the firmware file to AP / PDA
  8. Make sure re-partition is NOT ticked
  9. Click the start button, sit back and wait few minutes
  10. Before moving to step 11, you may want for it to get to the welcome screen as it sets up the phone.
  11. Wait until it says pass. It is then safe to unplug after that.
You can alternatively use the program called SamFirm to download samsung firmware at full speed (latest firmware updates only) or Updato (http://updato.com/firmware-archive-selec...) to download firmware too.
このアンサーは役に立ちましたか?
スコア 4
7 件のコメント:
hello there..I followed the procedure as described but upon finishing,the phone is still stuck at the boot loop..How do i go about this?
さんによる
Try doing a wipe data / factory reset through recovery mode and see if that helps, you could also have a bad data partition.
さんによる
The command,volume up+ home button+power button is not successful.The volume down+home button+power button is working and is putting me in the download mode whereby I managed to flash the phone through odin but the phone ended up being stuck on the logo upon restarting.
さんによる
Its a samsung phone
さんによる
no
it gives link to dwonload for money
and i dont have cridet card or cash
さんによる
2件以上のコメントを表示
コメントを追加
If you know the version of your i9200, 8GB or 16GB, it can be rescued. But you have to be sure of which one it is.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hi there i followed the steps on how to get in to odin mode or download mode i have samsung galaxy A6+ and when the phone is powered off i press the power button and the volume down key together at the same time so it appears the bootlogo and the odin mode don’t appear so how can i fix this problem please help me
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I am having the same problem, However I manage to get in odin mode by doing the steps in following manner
1) Plug in USB cable connected to pc at one end (phone will start and get stuck in reboot mode), dont worry, let it continue
2) PRESS Volume Down key + Home key (don't press power key)
phone will get into boot mode
さんによる
hi guys.
I tried firmware hard reset through odin3. it failed now my phone constantly restarts into recovery mode but only for a second, and goes on in an endless loop....
please help me guys.
さんによる
コメントを追加
回答を追加する
Douha Hashem さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 14
今までの合計 35,672
