メインコンテンツにスキップ
2015年3月に発表され、同年4月に発売されたGalaxy S6はGalaxyラインの中で最高のデバイスです。端にカーブが施されたスクリーンはGalaxy S6 Edgeです。
487回答 すべてを表示
Is it possible to repair a bricked S6 by changing motherboards?
Hello everyone. I happened to brick my S.6 sometime back so i was wondering wether its possible to bring it back to lifeby changing the "whole motherboard" and was still asking mine is an S6 G920F ...if i replaced it with another board of other variants would it still work ..Thanks in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
How did you brick your S6? Is it just stuck on the samsung logo?
さんによる
I have a s5active that wont go past the logo screen someone tried customizing the OS and bricked it Odin cant fix it any advice
さんによる
コメントを追加
2件の回答
最も参考になった回答
Yes changing motherboard will fix, other models will probably work, but there are slight physical differences between models, for example, sm-g920v will not fit sm-g920a... connectors are same, however lcd mid frame different and motherboard sticks out too much. I am not sure about which other models are exactly similar to sm-g920f
but better solutions is to flash stock rom using newest version of ODIN on your pc, samsung usb drivers, and a good samsung usb cable.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Well sometimes it depends
In ur case the motherboard of different varient are physically different so the only problem is that ur phone motherboard may not fit in the given space or locations of camera , speakers and sensors may be different
It may or may not affect.
In my case i got a motherboard of LG Tribute LS660(boast mobile ) for my LG Tribute LS660(VIRGIN MOBILE)
THIS CAUSE ME FOLLOWING PROBLEMS :----
1.i can not call for recive text messages
2. I can not charge my phone with charger
3. It sometimes get restart automatically
To fix this ,i replace VM motherboard
Thanks,
Phoenix701 a.k.a. The Unsatisfied Gamer,
I cannot tell my real name.
Ask anything about android to me anytime
Contact me : ---> pra tyushranjan9835@gmail.com
Never Be Satisfied...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lwanga Daniel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 1,165
