メインコンテンツにスキップ
Wii Uはハンドヘルドデバイスとペアになったゲームコンソールです。ユーザーは、GamePadでゲームをすることもできます。コンソールの修理は簡単で、デバイスはほとんどがモジュラーです。
191回答 すべてを表示
No audio/video on TV
Nintendo stated my device needed repair, but due to it being GameStop (whom won't do anything about it) refurbished, they won't touch it.
Is there any guidance on what may be causeing the problem or how to repair it? I can't justify the $299 for another Wii U as the Xbox One now costs the same.
To clarify, the issue is verified to be the result of a hardware failure. All plausible troubleshooting has been performed. I'm specifically looking for guidance on where I can get the equipment, and what man need to be done, for a DIY hardware repair.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント:
Can you describe the problem better as to what happened when it stopped working and what it does now?
さんによる
Currently the Wii U shows the blue light, my TV shows its trying to connect, then switches to no signal. This happened randomly a few months ago.
Wii U Gamepad will load options, but there is no audio or video on the T.V.
さんによる
Sounds like something with the motherboard.
さんによる
Often times this is the HDMI control chip, but not always! The chip is a panasonic MN864718, although the MN864718A will also do (I have confirmed this by re-chipping it myself with a version A). Hope this helps!
さんによる
コメントを追加
2件の回答
Have you tried plugging the Wii into another HDMI port on the TV and using a different HDMI cable? Hopefully it is a quick fix.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Yes, all troubleshooting has been completed and the issue is verified to be a failure of the hardware.
さんによる
unless you've gone to TV options and allowed it to hook up to the right settings the you really have done all troubleshooting.
さんによる
コメントを追加
I have no idea how to help you but if you no longer have a warranty then i'd suggest you open it up and mess with $@$* until you know what does what. From there you should look for a cheap seller of a broken one to see if it has all the parts and just swap things out.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Needs to be same model or it won’t work
さんによる
I'd argue that you could find a CRT on the side of the road and do it that way. The model is just a suggestion after all.
さんによる
コメントを追加
回答を追加する
matthew0 さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 10
過去 30 日: 17
今までの合計 1,763
