メインコンテンツにスキップ
The Alcatel One Touch Idol 2 features a 5" qHD IPS-LCD display along with a 1.3 GHz quad-core processor. It was released in February 2014.
Handset does not detect the sim card
Why my handset does not detect the sim card while the same sim card is detected on another handset
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
4件の回答
ベストアンサー
Hi,
Have you tried a different known working SIM card in your phone to see if it works?
If it works it may be a compatibility problem between your SIM card and your phone. Try replacing your SIM card with a new one and see if that solves your problem.
If it doesn't work you may have a faulty SIM card reader in your phone.
このアンサーは役に立ちましたか?
スコア 7
2 件のコメント:
I tried different working SIM card but still shows same.. Now the fault must be on SIM card reader.. Is any way to fix the it??
さんによる
Hi, As the card reader is mounted on the board you may need to take it to a reputable, professional phone repair service which has the expertise and tools necessary to do surface mount pcb component replacements.
Here is a video showing the dis-assembly of an Alcatel One Touch Idol 2. At 2:50 minutes into the video it starts to show the removal of the board on which the card reader is mounted.
https://www.youtube.com/watch?v=oZJZhbCm...
さんによる
コメントを追加
I woke up and it said no sim card I didnt take the sim card out but ehen I did it was powered off and It had already said no sim card emergency calls only what will cause this
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi, please can someone advise me, i bought a alcatel pixie 4, 5010x today, second hand. the shop, put their ee sim in. But mine comes up no sim, HELP
さんによる
コメントを追加
Hi it keep saying no SIM card but it is one in there help please
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Do not buy this phone, you will have this problem. They are not very durable. If you drop the phone you will have this problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Etu Tukuafu さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 5
過去 30 日: 18
今までの合計 26,833
