Why is the sound coming from my Tablet muffled?
Whenever I use my tablet the sound will come out muffled or distorted, and not as loud as it was a few days ago.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Is the sound normal when using a set of headphones plugged into the tablet?
If so check that the speaker grill on the back of the tablet is not covered, (by a case for instance) or if it is clogged. Do not poke anything into the grill, you may damage the speaker.
If it looks dusty/dirty try just a very quick suction action using a vacuum cleaner (on a low setting if possible) with an upholstery brush attachment and see if this improves the sound.
このアンサーは役に立ちましたか?
One of the reasons that can cause this is dirt, debris, or other grime stuck in the speaker or speaker housing. Gentle use a cloth and wipe away any on the outside or gently blow or used compressed air very lightly go over the speaker. This will help clear any grime out of the speaker and then test the sound again.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 12
過去 30 日: 32
今までの合計 5,454
