メインコンテンツにスキップ
5 MP camera with 12x optical image stabilized zoom. Released in June 2005
9回答 すべてを表示
Battery door wont open
Any idea how to get it open seems to be stuck
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Mine wont close. So the camera don not fonction anymore...
さんによる
I have a similar opposit problem. My camera's battery/door wont closed, so the camera do not work at all since. What should i do? I love this camera: Canon PC1310
さんによる
コメントを追加
2件の回答
ベストアンサー
To open the battery door on this camera
  1. Hold the camera upside down with the lens towards you
  2. Slide the LOCK switch to the right and hold
  3. Slide the battery door towards the front of the camera as far as it will go
  4. Flip the battery door open
If the lock switch won't move, it may be stuck due to dirt, or corrosion inside the battery compartment. A drop or two (not more!) of WD-40 might help in getting it moving again.
If the lock switch moves but the battery cover won't, either the locking mechanism is broken and stuck, or the battery cover itself is stuck, the latter is likely due to corrosion in the battery compartment. Apply a few drops of WD-40 around the seam of the battery door, wait a while and see if the battery door will move. Repeat the operation if necessary. Don't force anything. If the battery door still refuses to budge, take the camera in for servicing. Same thing holds if the battery door will open but there's abundant corrosion due to batteries having leaked.
If you succeed in opening the battery door with the aid of WD-40, remove any traces of the latter with a cotton swab and some alcohol: the solvents in the WD-40 may attack the camera's finish.
このアンサーは役に立ちましたか?
スコア 8
4 件のコメント:
Thanks soooo much I will give that a try! What would the world be like with Duct Tape and WD-40? :))
さんによる
Believe it or not, I seldom use either. Instead, I use Kontakt 70 and gaffer tape, but these are more difficult to get hold of for non-specialist. :)
さんによる
I got a rubber finger tip from office depot. Cut and Sewed on strap. Great!
さんによる
Thank you so much. I was struggling and you have saved my time and temper.
さんによる
コメントを追加
Finger tip from Office Store. Sewed on. Works great.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mark Herman さん、ありがとうございました!
統計データ:
過去 24時間: 11
過去 7 日: 33
過去 30 日: 129
今までの合計 28,138
