Remove rear fan assembly on a 2007 Mac Pro
How do I remove the rear fan/memory assembly from a late 2007 Mac Pro? I want to replace the analog audio input jack as it has become very intermittent.
Thanks
この質問は役に立ちましたか?
Thanks
この質問は役に立ちましたか?
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
このアンサーは役に立ちましたか?
what guide?
You have to remove all of your PCI cards, then your RAM extender boards.
These reveal four screws to unscrew. You can then pop out the rear exhaust
fan assembly by pushing it where the extender boards used to be. Then slide
that whole assembly the rear and separate it from the chipset heatsink.
After that it looks like you have to remove the heatsinks with an allen
wrench. Good luck
このアンサーは役に立ちましたか?
+ research
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 4,007
