メインコンテンツにスキップ
様々なテレビブランドとスタイルの修理ガイドならびにサポート
9051回答 すべてを表示
TV picture suddenly distorted
The picture on our LG V5500 LED TV all of a sudden has difficulty with certain colors. Some images seen clear but others are very funky. Dark colors in particular. Green splotches appear over darker colors with vertical lines appearing in the splotches.
Update (03/30/2016)
this is a picture of the current issue.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Steve Pearson,
If your television has image distortion issues, see the Insignia NS-24ER310NA17 Has Image Distortion problem page for possible causes and solutions.
This is possibly a LED driver board issue (around $40USD), a bad main board, or a bad LCD (unlikely) I'd go with a new driver board. This one should work
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you! I'll give it a try...
さんによる
コメントを追加
I had a plasma (as opposed to a LCD) and it did this and it was the logic board dying. I would suspect something similar is happening with yours. The repair parts alone were more expensive than a new TV, however your case may be different. A quick google with your exact model # and "logic board" may get you the answers you need.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Steve Pearson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 32
今までの合計 2,647
