Does this sound like a logicboard issue?
I'm wondering if you guys can help.
Got a G4 1.33 that will not boot.
Straight to flashing folder. When I boot using install disk (10.4) it usually gets only as far as a blue screen and hangs. I did get it as far as the utilities and
it could not see a HD to repair. Also fsck cannot detect any HD, only the Tiger install disk.So far sounds like a new HD is in order but before I pull it apart one thing bothers me. When I'm trying to boot, it will sometimes freeze on the grey screen, just stop mid boot and in target mode, if I let that run long enough it will freeze and the FW will stay stuck in the same place.
I wondering if it more likely a LB problem, what do you think, worth changing the HD?
Guidance appreciated
この質問は役に立ちましたか?
