メインコンテンツにスキップ
任天堂の数多くあるビデオゲームコンソール用アクセサリの修理マニュアルです。
23回答 すべてを表示
Sticky/Stuck joystick on my Wavebird
I have a Wavebird controller, and the joystick sticks in place when moved up and down. I have tried Electrosol cleaner in order to attempt to remove any contaminants, but it has not improved. Are there any other options besides soldering a new stick on?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Potentially it might need the whole joystick replaced. Inside of the controller there is a little box with moving parts inside (its how it works), and the parts can break over time. Especially with how old the wavebird is, you might want to try to find someone who could replace it for you.
and by replace I mean someone would need to take the controller apart, desolder the old analog stick, and solder a new one on.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yeah, that's my worry. I've taken it apart and checked the little box. There seems to be some kind of residue on the exposed plastic parts on the side.
I got it second hand, the seller didn't seem to test it before hand. Hoped to fix it and avoid losing out on the purchase. Might be out of luck.
さんによる
コメントを追加
回答を追加する
Sean Morewood さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 108
