メインコンテンツにスキップ
同名の社会的企業によって作られたフェアフォンの第2世代。2015年12月発売。モデル番号は FP2-XCVR
74回答 すべてを表示
Why isnt my phone turning on?
I let my Fairphone 2 battery die out and when I went to charge it again, it wont turn back on. I have let it charge for a whole day and it still isnt turning on. I have tried multiple chargers as well that are the spec Fairphone ask for. Sometimes it will go to the fairphone load screen and start showing the battery charge screen and says that it has 0% battery. After showing that the screen just goes blank.
when the charger is in the phone the red led light on the front is on, but that is even on when the battery is out.
is this a problem with the battery or a problem with the phone? My phone is only 1 month old.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
最も参考になった回答
Hello there,
Maybe this Support article will help you troubleshoot your issue!
https://fairphone.zendesk.com/hc/en-us/a...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had the same problem the other day and my phone was less than a week old, I'm not sure how to help, it then turned back on by itself, good luck.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Please let us know if you sorted the problem, thanks
さんによる
コメントを追加
My fairphone does not switch on anymore. It is not a battery issue as after switched on the first screen appears, but then nothing... please let me know whereto I can send it.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have exactly the same problem. I'm all ears/eyes.
さんによる
コメントを追加
My phone does the same thing, I tryed changing the bottom module, and it seamed to work for a while but then yesterday(feb) the problem came back, its worked ok since i changed the module in december
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Daniela Toale さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 8
今までの合計 3,004
