メインコンテンツにスキップ
The AmazonBasics BTV1 is a portable Bluetooth speaker that also includes a microphone for conference calls.
5回答 すべてを表示
Why isn't my phone pairing with the speaker?
When I enable the Bluetooth on my iPhone it still doesn't pair with the speaker. I tried turning it off and then back on but it still doesn't work. How can I fix this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
選択されたソリューション
The first thing that I would recommend doing is checking to make sure that the device that you are connecting with is compatible with the AmazonBasics Bluetooth speaker device that you are connecting to. Once you have checked compatibility, make sure that you are with in the specified range for the device to remain connected to the speaker. If the issue is still not resolved check the trouble shooting link for other possible solutions. Good luck! AmazonBasics BTV1 Troubleshooting
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Chris Shannon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 263
