メインコンテンツにスキップ
Wi-Fi, GSMとCDMA モデルのiPad第二世代です。あるモデルはiPad3発売前に改良されたものがあります。修理は困難で、熱で温めてこじ開ける作業が必須です。
730回答 すべてを表示
Screen NOT turning on after Screen Replacement
Hello Everyone, First time coming across this website and figured it wouldn't hurt to ask and hopefully someone will be able to help me figure it out. So here is the problem.
I am replacing a screen of the Ipad as it was cracked. The screen worked completely fine before i tried to replace it. I have it taken off and connected the new screen onto it. I then realized i didnt turn the ipad off so when i tried to turn the screen on when it was connected, it wasn't turning back on at all.
I tried doing the hard reset by holding the home button and power button. I also plugged it into a computer and it recognizes it as a ipad and that is all i did with that. I don't have a clue what is wrong and would REALLY appreciate the help as i need this fixed. :(
Thanks,
Austin
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
If turning the iPad off and back on again doesn't fix the problem, or the iPad is unresponsive when you try to turn it off, you have to reset it by doing the following: Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I have already tried doing a hard reset by trying to press the two buttons. is it because the home button isn't working or something? I haven't put the screen back on yet
さんによる
The Digitizer may not be making contact with the actual button on the iPad. Perhaps try holding down the power button then using your Thumb to press the button instead of using the actual home button?
さんによる
コメントを追加
iPad 2 Wi-Fi EMC 2415のバッテリーの交換
Just do step 42 and 43 and reassemble it again and try powering it on.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Austin Mcskillings さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 82
