メインコンテンツにスキップ
The third generation of the DJI Phantom series released in April 2015.
59回答 すべてを表示
Remove the camera so I can flip it
Today my Phantom 3 Standard crashed on the ground. This resulted in the camera being vertically flipped (DJI logo is on top upside down). How do I get the camera off the gimbal, so I can turn the camera and put it back on?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
I have just done the same thing, really wanting to know how to restore the camera to its original position...any help?
さんによる
コメントを追加
3件の回答
I had the same problem and fixed it. I assume you've fixed yours by now. If not contact me at mikewade54@sbcglobal.net and I'll walk you through it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello I am having same issue can u help please
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had the same problem after a crash. The only way I could find to fix was to take a very small flat tip screwdriver and wedge it between the gimbal stop then gently slid it to its forward position. My camera is facing a couple degrees to the left but for me it's a bent gimbal arm that I'll replace at a later time.
I hope this helps and I'd be extremely gentle if you try this.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
melvinerne1993 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 707
