メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
締切られた回答
LCD display horizontal lines
So I replaced the screen of my iphone a couple of days ago, thinking it'd fix everything and such. Didn't do it correctly and I wonder if I broke the cable in the process or if it's a motherboard/connector issue because the screen has been flickering, horizontal lines and the icons on the screen are 'doubling'. So...would a new screen assembly do the job or do I need a new logic/motherboard?
Something like this https://instagram.com/p/BDV-DaOPgFSG1NQQ...
https://instagram.com/p/BDV-K7CvgFeNxhYd...
Additional: setting it to high brightness made it go dark
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
this is normally:
damaged connection
damaged connector
damaged screen
or a lose connection
さんによる
How do I tell the difference? What should I examine? I mean, maybe I just bent the cable, but...
さんによる
コメントを追加
2件の回答
does it do the same thing with the old lcd?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Well, the original one had water damage and it's been somewhat similar as in unresponsive but since I 've removed the screens many times maybe I damaged the connector pins. I don't know. I tried rubbing some alcohol ( disinfectant) on the connector but to no avail. Perhaps I need to replace the logic board/ motherboard?
さんによる
if you have to replace the login board, it will be to expensive, might as well get a used one on craigslist or ebay.
さんによる
コメントを追加
Almost certain you will have to replace screen - avoid cheap replacement - try to get at least OEM from somebody reliable (Full OEM is preferable)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I should have tested the screen before installing so I'll never know if it's a defective screen. But I know it's not an OEM. I'll keep that in mind. Though, could this be a sign of a water damaged logic board?
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 296
