メインコンテンツにスキップ
Not Firing Or Turing On.
I have one of the Zeus Rival guns and for some reason its not firing at all. I have the ridiculous 6 C batteries in right but still nothing. I have also made sure to turn off the safety. I am going to have to open her up soon if I am unable to find a resolution. If anybody has any ideas feel free to help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 12
12 件のコメント
I had this problem too but it turns out there is a piece that connects to the top of the magazine which pushes a button which enables you to pull the second trigger and power it on.(my dad and I had to take apart the whole gun to figure it out lol
さんによる
Mine shoots but jams every time
さんによる
When you open the hatch on the right of the gun, you have to push it down very hard to lock in place, then it works
さんによる
Lewis Conner, thanks, that did it.
さんによる
I have a problem with my rival Zeus I have not checked the batteries yet but it does not want to let me pull the trigger does anyone have a fix ?
さんによる
7件以上のコメントを表示
コメントを追加
12件の回答
最も参考になった回答
Try re-solderingvthe wire in the battery tray
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
If the trap door near the barrel is open even slightly it will not fire.
さんによる
THANK you. I was about to return the %#*@ thing lol
さんによる
Yes... the trap door being completely closed was the key! Thank you!!!
さんによる
Holy $@$* I was about to return it thank u so much it was the trap door shut it ALLLL the way even when u think it’s closed
さんによる
OMG I just bought all new batteries and was about to return it. Wow thank you!
さんによる
1以上のコメントを表示
コメントを追加
First you look at the orange hatch , the one that opens up. Second that hatch is not fully closed so you need to close it until you here a snap or a click then it should work.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
It is awesome
さんによる
Incredible simple, this was the problem, thanks.
さんによる
コメントを追加
Did ya unjam the wheel part? I'd there is a ball in the wheel part it will not fire.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I keep on taking it out but it rejams and bearly goes far
さんによる
Mine does the same but mine doesn't even shoot
さんによる
コメントを追加
On some nerf rival there is a trap to un jammed when the ball is stuck and if this trap is not correctly closed(you should heatd a “clic”) the electric motor doesn’t work. I spent 1 hour disassembling the gun etc… when i realised i was ready to send it back.
hope it’s helpfull.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Did u figure this out?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Ive done all of this and it still doesn’t work.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
what do you do when the moderriser on the gun dose not work
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This is a common issue. The springs touching the battery pack get compressed and need to be stretched out. It’s a simple operation, remove the battery pack and unscrew each screw. Pop the left side off then pull, baby, pull. On the springs that is.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How to fix nerf gun rifle
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
how do you fix one
さんによる
コメントを追加
e
w3=-ero40ynihio-jk-4p5ymnt-35g
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
When closing the jam clearing hatch/port near the muzzle on the right side, you need to pull the sliding door forcefully until it clicks (there is no indication of this, and the door appears closed, but you have to pull hard until it clicks). That would engage a switch to deactivate a safety feature and connect the power to the pump.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My is not reloading
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joseph さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 23
過去 30 日: 117
今までの合計 44,272
