メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Auto brighness toggle is missing after updating the iOS
After updating my iphone from iOS 8 to iOS 9.1 the auto brightness toggle went missing. It is not appearing in Settings-> Display&Brightness or anywhere else in Settings. I have tried DFU Restore, Reset all settings, hard restart and still it is missing. I’ve updated to iOS 9.3 but still no result. With the slider for brightness I can change the brightness and it is working fine.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
7件の回答
ベストアンサー
I remember having solved this on an iPhone 4S, the problem was not in the light sensor, was another piece that was giving short circuit on the plate.
Incredibly, it was solved by changing the flex charger, which has nothing to do, but he was giving a short circuit, which did not work to the brightness sensor.
Try disconnecting the flex power and flex charger and see if it works.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I have just changed the flex charger cabel and made DFU restore but still missing the auto brightness.
さんによる
You need change this flex
This flex have a sensor brightness,
If you change this flex, but don't fix, is a problem in the board.
iPhone 5 Front Camera and Sensor Cable
さんによる
Changing the flex cabel with front camera and sensors plus iTunes restore helped me. Thanks
さんによる
コメントを追加
最も参考になった回答
Try going to General > Accessibility > Magnifier. Auto-Brightness may be in there.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
That’s the auto-brightness for the camera, not the display
さんによる
Thanks, it did the job, adjusts the display brightness day and night
さんによる
コメントを追加
I have an iPhone 6s Plus with ios 11.1.2 . It is not found when I go to settings general accessibility display accommodations. Instead it says "Turning off auto-brightness may affect battery life" but there is no switch to turn on or off.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The ios has again changed the place so please find in Setting-General-Maginifier-Auto brightness.
さんによる
コメントを追加
Have you tried placing the phone into iTunes mode and then restoring the device through iTunes?
If this hasn't worked, all sources point to this being logic board failure and may need to be returned to Apple.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Yes I have tried this but still missing. :(
さんによる
The ios has again changed the place so please find in Setting-General-Maginifier-Auto brightness..
さんによる
コメントを追加
I have the same problem ... I've updated my iphone 5 from ios 9.0.2 jailbroken where it had the auto brightness setting to ios 9.3.2 and now is just missing
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem, also did all the above steps with no luck, i dont see why it would be the board as the front camera still works fine and the camera brightness adjusts accordingly when focusing a photo, at times my screen auto adjusts brightness, but not all the time. This all leads to software. Im looking for ways to get it fixed and will let you know if i have any luck. Mine also disappeared after update sinse ios9.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I found it under General > Accessibility > Display Accommodations.
It has a warning about battery life - which makes sense
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Todor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 18,241
