Where can I get a replacement screen
bugs are eating my screen. where can i get a replacement screen
@saillll it will be pretty close to impossible that you will find a replacement screen. It will cost more than a complete new TV. I suggest that you try and find your model TV that has other issues and is no longer working but has a good LCD. Than use that one to harvest the LCD screen from it. Explain the bugs eating your screen a bit more. Never heard of that,
このアンサーは役に立ちましたか?
You might want to check EBay, or Craigslist for a used TV like yours. If you can find a working model, I would keep it as the working TV' and strip your current set for spare parts. It would probably be cheaper and less time consuming then changing the screen.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 12
今までの合計 352
