メインコンテンツにスキップ
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140回答 すべてを表示
Water leaks from brew head when powered on
My Starbucks Barista drips water from the brew head when the machine is turned on and stops when the ready light turns green. I have stretched out the spring and replaced it but it still drips. What else could the problem be? Do I need to replace the group head gasket? Should I replace the tension spring?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
If it only drips a little and stops once the machine is up to temp this is nothing to worry about, as well as any dripping heating up to steam temp. If it drips excessively and/or doesn't stop then you could try replacing the silicone nipple on the end of the spring, or the spring itself, but the group head gasket plays no role in this.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Carlie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 494
