I Cant Get My Watch To Connect To My Computer
When I plug my watch in to my computer, I cant get my computer to connect. I have had my watch for a while, maybe it is just too old?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
To start tackling your problem we have to make sure the Nike Plus Program is installed correctly on the computer. First you will need to download the program from [Nike Plus Connect] , after that just run through the installer to get a fresh copy of the program on your computer and then try connecting the band again. If reinstalling the program does not work you can try restarting the computer to see if the problem is with your USB port. Last but not least if you are not able to connect your device you can contact Nike directly to ask them for a band repair. If you have any further questions you can just reply to this answer. Thanks.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 744
