メインコンテンツにスキップ
AmazonのKindlePaperwhiteシリーズのこのイテレーションは、2015年6月30日にリリースされました。KindlePaperwhite第3世代は、Wi-Fi対応の6インチ300PPI読み取りディスプレイタブレットです。 指定モデル番号はDP75SDIです。
Why does my screen get stuck on a page when I’m reading?
I’m having trouble with my Kindle sometimes when I turn the page. The problem is that when I try to turn the page, the page won’t change, and I’ll try again a few times and it will either take a few minutes just to simply turn the page, or it will freeze completely and I’ll have to refresh my Kindle in the middle of my reading. Is there any way to fix this, or is my Kindle just slow?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 8
1件のコメント
My kindle fire is frozen. I am unable to get to home page nor settings. I have tried to turn it off and that doesn’t work either. Any suggestions?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi Delroy! Don’t worry, that’s a very common problem with Kindles, and the solution is relatively simple. What you need to do is go to settings and turn the page refresh on. This makes it so that the screen refreshes every time you turn the page, which should solve the problem. So first, hit the settings button on the top right of the screen, then go the reading options, and finally turn the page refresh on. Also, to simply improve overall speed, it might be a good idea to delete some unnecessary data that’s stored on the device, but the page refresh should work. Hope this helps!
このアンサーは役に立ちましたか?
スコア 6
2 件のコメント:
My kindle wouldnt turn page i followed the 40 sec hold button in it rebootedby the screen niw frozen on home page, i e ffollowed e erything including putting it on charge its now fully charged but still stuck on home page, settings back store on top of screen nothing works
さんによる
I have a brand new Paperwhite and I notice that when I’m reading outside in the bright sun, page turning is somewhat problematic. (Behavior similar to that described by Delroy Fong.) I will try the page refresh tip and see if that helps.
さんによる
コメントを追加
回答を追加する
Delroy Fong さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 31
過去 30 日: 137
今までの合計 30,469
