メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
Home button is not working
I have an iPhone 3g and the home button is not working, well I say not working, but I am finding that I have to really push hard on the button to make it work!!!
Please can any one tell me what the problem is and how to fix it?
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
ベストアンサー
There is no soldering needed on this part! Home button flex connects to top of dock flex not the motherboard.
If button is still responsive but needs more pressure try following guide to open iPhone, disconnect ribbons1,2,3. Turn display over and you should see the 2 gold prongs beneath home button- use a small flathead screw driver to gently lift them up. Clean top of dock to get rid of dust etc. Reassemble. Gold prongs get flattened with use, they should be pointing upwards approx 45• to make contact with dock
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
この回答は他の質問に帰属しています。
Try this first. Reposting from Ezekiel's solution that works!
Its a hardware issue that Apple overlooked. Try this work around to save money. Plug your iPhone USB cable into the phone (No need to plug the other end to anything) and grip the part right where it is plugged into the phone. Slightly bend it up towards the screen, just a little (You might even hear a click) and presto! This is guaranteed to work most of the time. If it doesn't, you need a new Home Button then.
Just dont blame anyone if you break something because this work around relies on your own strength..Ü
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
この回答は他の質問に帰属しています。
try to calibrate your home button by doing this press power button until slide diplayed but do not turn off press home button where your finger point on exact position, try and try until you got your button function normal. good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Probably just needs a replacement home button flex, these can be found on ebay. Although if your unlucky the contact on the logic board may have come off, these are replaceable too but the soldering can be a tad fiddly.
このアンサーは役に立ちましたか?
スコア -1
コメントを追加
回答を追加する
Paul Foster さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 28
今までの合計 8,710
