メインコンテンツにスキップ
大きめのアップルMacBook Airラップトップはデュアルマイクと802.11ac Wi-Fi接続を特徴としています。
465回答 すべてを表示
Fan Issue and stuttering even after SMC and PRAM Reset
Hi,
I have a Medio 2013 Macbook Air i5, 4gb ram, 128 SSD.
Recently the fans started spinning up to 6500 rpm (I use Monity to check), that is full speed. usually it starts right as i turn on the laptop - around half way through the loading bar the fan starts spinning up, by the time i hit the log in screen its at full throttle (Mind you that takes around 7-12 seconds from cold boot).
The computer is also very slow once this happens, and even simple tasks like opening a tab in google chrome makes it stutter, lag, and shw the spinning rainbow wheel of death (srwd from now on).
I have not yet reformatted the laptop, because i get an error that it failed everytime i try. another issue i suppose? But i am going to reinstall OSX and see if that does anything.
I heard that this is a common issue and that an SMC reset should fix it - sometimes it does, but only for a few hours and it starts back up and the computer slows back down. When this happens Monity shows CPU System usage as 70+ %, as if OSX is using the entire cpu for something.
I did a PRAM reset as well with no changes.
Additional info:
Do i need a new battery? I'm uncertain of where the SMC is located on an Air.
My charger uses a little converter bit, which im not sure is standard on macbook air chargers, but it is made by apple so it shouldnt be a problem.
I'm new to mac, so i am not sure why or what i can do. Any help is greatly apprecieated !
MacBook Air, OS X El Capitan (10.11.3), Medio 2013
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi alanmk,
I had the same issue on the same macbook air bought in December 2012.
Exactly one year ago the fan of my Macbook air started to speed up just before
Mavericks boot, so I tried:
1. Update to Yosemite, not solved
2. Update to El Capitan, not solved
3. I brought the laptop to Apple support and after paying 50€ the guy told me that I have to replace the motherboard, for a lovely price: 650€. So I refused and keep trying to solve by myself.
4. Tried SMC and PRAM reset, not solved.
5. In january I installed a Linux Distro on the Macbook Air, not solved again.
6. After a while a realised that the problem was in the Mac firmware: the minimum speed for fan was 6500rpm, which is also the maximum!!
So I installed a simple fan controller: https://github.com/dgraziotin/mbpfan
and solved the problem.
I suggest you to simply try something like https://www.macupdate.com/app/mac/23049/... for OSx.
I just want to make clear that the problem was a firmware parameter, since I noticed the same problem both on OSx and Linux and double checked this with mbpfan.
The questions are why this happened since I have never update the firmware? and why I have read many times in forums that I have to replace the motherboard with no reason?
Hope this help
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
alanmk さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 3,711
